| Author |
Message |
kyle Member
Post subject: benchmark tests Posted: Fri Jun 18, 2004 5:02 pm
| I was just wondering if anyone could give me some pointers for running benchmarks on my new system...?
| Back to top
Adam His Excellency
Post subject: Posted: Fri Jun 18, 2004 10:56 pm
Use sisoft or other tests mentioned in the forums.
Also use this to burn in your cpu, it's a cool project too:
http://www.computersoc.com/viewtopic.php?t=17
_________________ Fast computers wanted to cure diseases: Distributed Computing
Please consider upgrading to an Advantage Account. It helps the site's expensive costs. Thanks! |
| Back to top
ice Member
Post subject: Posted: Sun Jun 20, 2004 5:34 pm
www.madonion.com has the 3DMark tests everyone talks about, to bench your gaming performance.
Also run a search at Yahoo for Aquamark, which is another one. Pretty sure it's Aquamark, I just had a brain fart and lost what I was thinking
| Back to top
Dexter Member
Post subject: Posted: Sat Jun 26, 2004 9:31 pm
You are correct about aquamark. Aquamark is one ripped benching program...kinda set up to try to make your computer choke on a data load.
It definately is a good test.
_________________ - The Titanic wouldn't sink if they had duct tape.
- Whatever it is I didn't do it
Dexter the custom computer guy
Sheriff of the Hardware/Software Discussions.
*Woody from Toy Story's Voice* "Reach for the Sky!" |
| Back to top
stupidd Site Police
 Joined: May 05 2004 Posts: 542 Location: South Carolina
Post subject: Posted: Sun Jun 27, 2004 2:29 am
| obviously, 3dmark for gaming benchmarks, but are there specific tests for memory, hard drive, and cpus?
http://www.flickr.com/photos/cgancos/ |
| Back to top
Dexter Member
Post subject: Posted: Sun Jun 27, 2004 2:10 pm
Sisoft Sandra 2004 benches everything under the sun in it's various modules of testing. It will even test network card performance from within a private network, or to a registered outside source on the computer (like an FTP source I believe will work for that test). CPU has 2 different tests, and most other components just have 1 single test, but is compared to high end toys.
Lemme know if you want a copy, I can maybe send you it.
| Back to top
ice Member
Post subject: Posted: Sun Jun 27, 2004 7:27 pm
| Yesh, Sisoft Sandra is great.
| Back to top
Mauri Antero Guest
Post subject: Posted: Tue Jul 20, 2004 2:59 am
SuperPi, Hexus_pifast, 3Dmark 01 03, PCmark.....
| Back to top
Mauri Antero Guest
Post subject: Posted: Tue Jul 20, 2004 5:37 am
To add memspeed isnt everything but the timing. That previous was driven with OCZ 3700 EB, but those timings are the fastest that they support. This other one is runned with KHX3000 but with extreme fast timings.
| Back to top
Adam His Excellency
Post subject: Posted: Tue Jul 20, 2004 5:43 am
Welcome to computersOC! You should register!
Did you run Sisoft or 3dmark2003 yet?
Here's a crunching program that uses the CPU that you should join too... you'd probably woop us all.
http://www.computersoc.com/viewtopic.php?t=16
| Back to top
Post subject: Posted: Tue Jul 20, 2004 6:03 am
Adam My UD stats
Extreme HC overcloking for long time, but no screenshots from Sandra or 3Dmark 01 and 03, last 3DMark 01 result was 30 089 and 03 about 12800.
| Back to top
Mauri Antero Guest
Post subject: Posted: Tue Jul 20, 2004 6:14 am
Found some "old" benmarks with my old prosessor. btw I'm an Finnish 38 years "young" overcloker.
| Back to top
Adam His Excellency
Post subject: Posted: Tue Jul 20, 2004 9:27 pm
Wow, 277 for UD, nice. My Athlon XP 2400+ that I just un-overclocked, gets 188. Did you join our team?
| Back to top
Mauri Antero Guest
Post subject: Posted: Wed Jul 21, 2004 4:09 am
| Adam wrote: | Wow, 277 for UD, nice. My Athlon XP 2400+ that I just un-overclocked, gets 188. Did you join our team?  |
I'm sorry but already got a Team where to crunch. btw ages ago had axp2400+ and it went easilly to 2300 Mhz, so whu underclock?
| Back to top
Adam His Excellency
Post subject: Posted: Wed Jul 21, 2004 4:17 am
I had it over 2300 MHz too. I underclocked partially because of the summer heat and the computer was too noisy.
| Back to top
Mauri Antero Guest
Post subject: Posted: Wed Jul 21, 2004 5:09 am
In that case I'll understand, right now got this a64 3700+ running @ 2796 mhz which is my 24/7 setting now. Cooling this with Prometia Mach II witr r404 mod, cpu temp raises about 16ºC with full load, on idle (what that is ) it drops to -17ºC. Still too hot for me, but so far for 24/7 use compressor is the best solution. Have started my oc career with aircooling, moved to watercooling and now got compressor. Have also tried LN2, but for 24/7 use way too impossible and expensive.
[/url]
| Back to top
Adam His Excellency
Post subject: Posted: Wed Jul 21, 2004 5:14 am
Cool. Did you ever crunch the TSC program? That has results that are more consistent for the average time. I've seen the average about 34 seconds on a 2.0GHz Mac G5. I'd be nice to see that overclocked but it won't happen.
| Back to top
Mauri Antero Guest
Post subject: Posted: Wed Jul 21, 2004 5:53 am
| Adam wrote: | | Cool. Did you ever crunch the TSC program? |
Nope, I'll just crunch UD. Gotta try that but wont stay long to to crunch TSC
| Back to top
| View previous topic :: View next topic |
