 Date/Time is Fri Feb 15, 2019 5:19 pm
Ivy Bridge Temperatures Its Gettin Hot in Here
xp cleanup / maintain / command line fun / batch programming
Goto page Previous 1, 2
Post new topic Reply to topic Computers OverClocked Forums - Operating Systems All times are GMT - 5 Hours - EDT
somebody1
PostPost subject: Re: xp cleanup / maintain / command line fun / batch program
Posted: Thu Feb 28, 2008 8:34 pm
I actually was going to add ad-aware support to this, but realized you had to have the paid for version, instead of the free version. I wanted everything to be obtainable freely.
I will explain scripting of Ad-Aware farther down, but you don't need a script to log it, It is in Ad-Aware itself, and if you have that option selected, if you run Ad-Aware from a script it will then log (but you have to save it before removing the malware)
Goto Settings>Tweak>Logfiles> check what you wish to log.
(see attached photo) however it does not save this, you have to do this manually by right clicking it, and hitting save.
I'm sure you would like an automated way of doing this, if it would at least save it somewhere you didn't want the log file to be, then you could put in the script to copy it to another location, but it doesn't save any log.
Personally i would bug the people at lavasoft to make a feature to automate the log files, or show you how you can do it:
http://www.lavasoftsupport.com/index.php
Scripting help:
You would need to create a text file called anything you want to, but instead of the default .txt extention use the .bat extension that makes it executable.
then the code would look something like this:
This is the best way to do it, since it would work on any windows setup:
%PROGRAMFILES%\Lavasoft\Ad-ware\aware.exe variablegoeshere
list of variables you can add to the script:
http://www.lavasoftsupport.com/index.php?showtopic=205
NOTE:
You can't run a script using C:\Program Files\.....
It would have to be "C:\Program Files\..."
If you have any problems just show me the location in full where your adware exe is, and i will make one for you.
 Filesize:  69.56 KB
 Viewed:  452 Time(s)
vphreeze
Posted: Thu Apr 10, 2008 10:50 pm
ran into an issue. i downloaded the file and extracted the folder to C:\Program Files\Maintain. i ran the program and had it install Regseeker and Spybot. when i run maintain.exe, check the boxes i want (all but "shutdown"), and click F5 i get the error in the attached image...any ideas?
in additin to this, i have 2 questions: are you still planning to make an installer? how hard would it be to add the ability to have an option to run Avast Antivirus silently like the other programs?
 Filesize:  5.13 KB
 Viewed:  12430 Time(s)
somebody1
Posted: Fri Apr 11, 2008 8:06 pm
Hey Vphreeze, thanks for your interest in my program.
I have never used Avast, but will look into if Avast can run sliently.
Can you take off all the check boxes, then try it with only 1 checked at a time, tell me which check boxes gives that same error, and which check boxes does not.
Also if you are running Vista this was made for XP, and does not support vista.
vphreeze
Posted: Tue Apr 15, 2008 3:24 am
sorry it took so long to get back to you, i was off work over the weekend and dont get much net time at home.
i have tried it with all the boxes, each one idividually and with no boxes checked, they all give the same error. i am using XP. is it possible that i took something out of my copy of XP when i ran it through nLite? i didnt remove a whole lot, i tried to keep it to mostly just the "bloat", like the Windows Tour and extra keyboard languages and stuff.
somebody1
Posted: Thu Apr 17, 2008 6:54 pm
yes, nLite is possibly the problem. This program was coded in VB which requires some bloated XP files.. Mad lol.
Try this runtime package, it may fix your issue:
http://www.alphawolfpack.org/downloads/Computer_Maintain/VB6.0-KB290887-X86.exe
If that don't work, you may have to have .NET package for it to work.
sambisu
Posted: Wed Apr 30, 2008 2:02 pm
I am having the same issue. Tried that link you just posted, but that didnt seem to help at all.
"If I hadn't cut across corners my whole life, I couldn't be where I am today because I couldn't have walked that far"
somebody1
Posted: Sun May 04, 2008 9:14 pm
Are you also running nlite or a modified version of XP?
Also check windows updates make sure you have all the .NET patches.
I am not sure if i actually posted any instructions for this program or not, but you must goto File > Compile before you attempt to run, or when you alter any settings.
I thought i changed it in a later version, but I can't seem to find it.
fifatechno
Posted: Mon Aug 31, 2015 10:24 pm
auto removes registry entries that can be safely removed (old entries, currupts, etc..) ive been using this program for at least 3-4 yrs no problems.
PostPost subject: xiaozhengm
Posted: Tue Oct 27, 2015 11:23 pm
2015-10-28 xiaozhengm
Ugg Boots,Ugg Boots Outlet,Ugg Outlet,Cheap Uggs,Uggs On Sale,Ugg Boots Clearance,Uggs For Women
Discount Clearance Coach Outlet Handbags
Christian Louboutin Outlet Authentic Sneakers Online
Louis Vuitton Outlet High Quality
Prescription Oakley Sunglasses Wholesale
Jordan Retro 8 Playoffs
uggs australia
Louis Vuitton Neverfull GM Monogram
Ray Ban Outlet Store Online
Designer Handbags Louis Vuitton
Air Jordan 4 Green Glow
Coach Outlet USA Stores
Abercrombie Short T-Shirts
Coach Outlet Official Website
Jordan Retro 13 Pink And Grey
Canada Goose Jackets Outlet Online Sale
jlgg
PostPost subject: jlgg
Posted: Wed Dec 16, 2015 10:32 pm
coach tote bags outlet
Prada Clearance Sale
Ugg Sale Boots
Cheap ugg boots
coach bags on sale factory outlet
louis vuitton shoulder bag
cheap ugg boots from china
Coach Purses Outlet Online
louis vuitton wallets for men
coach sunglasses for women
Ugg Sale 2016
Prada Totes
cheap louis vuitton purses
hermes birkin price list
Hermes Belts for Cheap
louis vuitton belt for men
cheap ugg boots for women
burberry belt
free ugg boots
cheap michael kors clutch
uggs australia
louis vuitton artsy handbag
ugg kids sale
discount michael kors bags
louis vuitton zippy
MCM Backpack
burberry crossbody bag sale
longchamp tote bag outlet
Prada Nylon Messenger Bag
mcm tote bag
burberry wallets for women
Coach Purse Outlet Online 80% Off
cheap louis vuitton belts
Cheap Ugg Boots
Burberry Shoes Sale Women
michael kors black purse
louis vuitton messenger
longchamp le pliage medium shoulder tote
burberry handbag
Coach Crossbody Sale
discount louis vuitton diaper bag sale
Prada Nylon Backpack
trx straps
michael kors tote
Nike Hyperdunk Shoes
michael kors purses
ugg for cheap
Chanel Clutch
Coach Handbags Sale Outlet
prada backpack purse
prada clutch
MCM Bags at Macy's
ugg online sale
burberry bags on sale online
longchamp backpack purse
Lebron 13
MCM Handbags
trx for sale
Longchamp Tote Bag Outlet
michael kors crossbody bag
longchamp tote
Prada Shopper Tote
chanel bags prices
louis vuitton speedy 35
ugg sheepskin boots sale
Coach Bags
louis vuitton duffle bag for men
Ray Ban Outlet
coach crossbody
cheap uggs clearence
burberry crossbody
ray ban online
louis vuitton travel bag replica
Burberry Crossbody Bags
cheap louis vuitton speedy
MCM Backpack sale
michael kors hamilton tote
uggs on sale for women
Gucci Backpack for Sale
burberry backpack
louis vuitotn speedy
louis vuitton handbags sale
uggs clearence sale
prada clutch bag
louis vuitton artsy mm
Burberry Outlet Locations
Ugg Outlet Online
michael kors purses on sale
louis vuitton belt
ugg leather shoes
Ray Ban Outlet store
michael kors purses outlet
Prada Outlet
Chanel Tote Bag 2015
Burberry Handbags On Sale
Authentic Louis Vuitton Eva Clutch
burberry tote
michael kors tote bags
burberry purses
louis vuitton damier
chanel tote bag
birkin bag hermes cost
ugg boots for men
Gucci Handbags Outlet
Fendi Belt
uggs australia outlet
mcm backpack price
michael kors satchel
Coach Sunglasses Outlet
Womens Ugg
free ugg
longchamp le pliage large tote sale
Louis Vuitton Tote Bags
sheepskin boots for women
michael kors black handbags
hermes birkin price
mcm purses
prada tote
prada belts
michael kors handbags on sale
Burberry Tote Bags
Longchamp Medium Shoulder Tote
Ugg Boots
Outlet Michael Kors Handbags
ugg bailey button triplet
Hermes Birkin Price 2015
burberry men cologne
hermes purses prices
Ugg Boots sale
Ugg Outlet sale 2016
chanel bags outlet authentic
gucci cross body bag messenger
Louis Vuitton Damier Ebene bag
mcm duffle bag
burberry men
burberry sale online
Longchamp Le Pliage Sale
sheepskin boots
hermes belt price
gucci luggage outlet
cheap michael kors satchel
Burberry Clearance online
louis vuitton wallet for women
louis vuitton shoes men
mcm clutch
prada messenger bag in nylon
michael kors crossbody handbag
ugg snow boots store
louis vuitton mens wallets cheap
ugg snow boots for women
burberry handbag sale
Chanel Flap Bag Price
burberry belt men
louis vuitton monogram
burberry for men
longchamp sale outlet
louis vuitton alma
cheap michael kors tote
hermes purses
trx ab workouts
cheap coach purses from china
prada purses and handbags
Oakley Outlet
michael kors bag
Coach Factory Outlet Online
discount uggs
free shoes
ugg outlet sale 2015
ugg women boots
louis vuitton artsy
MCM Outlet Store
Longchamp Bags Macy's
Burberry Backpack for Women
ugg bailey button boots
Gucci Luggage Outlet
coach diaper bags on sale
prada handbags sale
burberry purses outlet
uggs australia boots
Cheap Ugg Boots
michael kors bags on sale
ugg on sale for women
mcm rucksack
MCM Factory Outlet
coach crossbody bags
Prada Handbags Outlet
Louis Vuitton Bags
burberry wallet
ugg online shop
MCM Bags at Macy's
Burberry bags
Coach Outlet Store Online
louis vuitton tote
authentic louis vuitton duffle bag
Prada Women's Loafers
mcm handbags at bloomingdale's
Gucci Crossbody Handbags
michael kors tote
michael kors purse outlet
burberry diaper bag
louis vuitton zippy wallet
mcm purses handbags
gucci luggage
Prada Cross Body Nylon Bags
trx
coach diaper bag
burberry shoes for men
Burberry Outlet Online
MCM Handbags
Uggs On Sale
louis vuitton artsy
MCM Bags at Macy's
MCM Bags at Macy's
prada loafers
michael kors handbags cheap
coach purses on sale
Louis Vuitton Shoulder Bag Tote
Kobe 10 Shoes
discount louis vuitton purses
trx exercises
Longchamp Backpacks Nylon
louis vuitton watllets
coach crossbody handbags
Hermes Outlet
Nike KD 7
gucci handbags outlet
MCM Bags on sale
Coach Wallets on Sale Outlet
Burberry Handbags Factory Outlet
louis vuitton wallet cheap
Authentic Louis Vuitton Neverfull
prada tote bag black
ugg bailey button
MCM Handbags price
discount louis vuitton purses outlet
coach purses on sale macy's
Burberry Men's Shirts
Coach Laptop Bag
coach handbags sale outlet
coach hobo bags outlet
Authentic Louis Vuitton Neverfull bag
prada outlet online usa
michael kors clutch
trx for sale
Michael Kors Purses
chanel bags prices fall winter 2015
KD 8 shoes
vintage chanel bags
Nike Kobe 10
coach messenger bag for women
prada bags on sale
trx for sale
ugg slippers for men
gucci sunglasses for women on sale
Burberry Wallets Women
burberry store Washington
coach purse outlet
mcm tote bag
Cheap Purses Michael Kors
Ray Ban sunglasses
burberry tote sale
ugg womens
coach backpacks on sale
trx workout
ugg sheepskin boots
louis vuitton tote bag
Gucci Belt
cheap michael kors purses
prada belts for men
Nike Lebron 12
louis vuitton alma bag
michael kors tote
burberry backpack for women
cheap michael kors purses outlet
Coach Outlet Diaper Bag
michael kors purses
gucci messenger bag
burberry for men cologne
uggs
MCM Bags
louis vuitton messenger bag
trx workouts
Gucci Sunglasses for Women on Sale
Sunglasses for men
prada crossbody bags
gucci handbags outlet authentic
burberry belts for men
Louis Vuitton Monogram Canvas
gucci clutch
Chanel Factory Outlet
Cheap MCM backpack
chanel flap bag
louis vuitton travel bag men
coach purse outlet online 80% off
cheap gucci belts for men
louis vuitton eva clutch
Discount Sunglasses
louis vuitton handbags on sale
Gucci on Sale from Factory
Ugg sale
MCM Outlet
louis vuitton neverfull
uggs for cheap
Ray-Ban Sunglasses
Coach Factory Outlet 85% Off
chanel flap bag price
michael kors clutch 2015
MCM Factory Outlet
sheepskin boots on sale
burberry shoes
prada messenger bag
cheap uggs on sale
Longchamp Factory Outlet Online
discount ugg boots
cheap louis vuitton tote
Louis Vuitton Damier Azur
gucci purses
Louis Vuitton Diaper Bag
black ugg sheepskin boots
ugg leather boots
cheap ugg boots 80% off
discount michael kors tote
cheap louis vuitton handbags
chanel tote
coach crossbody bags on sale
ugg leather short boot
coach sunglasses
michael kors factory outlet online
louis vuitton speedy 25
Ugg for women
cheap louis vuitton shoes
ugg for sale
ugg boots for sale
birkin bag hermes
Louis Vuitton Eva Clutch Bag
Nike Lebron Shoes
uggs clearence
gucci clutch purse
Hyperdunk 2016
MCM Outlet Sale
MCM Outlet store online
mcm clutch bag
Cheap Ray Ban
louis vuitton belts
ugg snow boots
coach hobo bag
UGG Outlet
ugg women's classic short boot
vintage chanel bags for sale
mcm outlet sale
prada purses
louis vuitton belts for men
gucci purses and handbags
gucci messenger bag for women
ugg kids
michael kors store online
coach diaper bags
gucci backpack
louis vuitton speedy 30
ugg slippers for women
Vintage Chanel Handbags
trx straps
louis vuitton diaper cheap
louis vuitton shoes
Burberry Cologne for Men
Prada Factory Outlet Store
mcm handbags
prada backpack
discount michael kors satchel
MCM Outlet Online
longchamp bags macy's
Mens Sunglasses
MCM Cheap Duffle Bags
chanel bags outlet
Cheap Real Gucci Belts for Men
mcm tote bag under 100
cheap trx straps
Louis Vuitton Outlet Online Store Authentic
Nike Hyperdunk 2015
michael kors on sale
coach handbags sale
Louis Vuitton Red Alma
mcm bags at macy's
burberry belts
Oakley Sunglasses Outlet
mcm duffle bag for sale
prada-crossbody
coach messenger bag
trx band workouts
prada tote bag
uggs for sale
ugg slippers womens
Prada Clutches on Sale
coach tote bags
louis vuitton purses on sale
coach wallets on sale outlet
gucci bags outlet
burberry diaper bag on sale
gucci backpack for men
Louis Vuitton Messenger Bag
prada handbags sale online
longchamp backpack
Ugg Boots Outlet
coach bags on sale
coach backpack
Price of Hermes Purses
cheap gucci belts
ugg slippers on sale
Sunglasses outlet sale
ugg kids boots
Louis Vuitton Diaper Bags
cheap louis vuitton wallet
mcm tote
gucci diaper bag
Cheap Sunglasses
louis vuitton neverfull mm
uggs for women
Louis Vuitton Monogram Tote
prada crossbody bags on sale
Chanel Bag Prices 2014
Burberry Crossbody Sale
MCM Clutch Bag
louis vuitton belt price
Cheap Oakley Sunglasses
prada loafers women
gucci diaper bag on sale
burberry store
Gucci Belt
cheap coach purses
Kobe X Shoes
discount ugg boots for women
michael kors hobo bag
jeanramos
Posted: Fri Mar 10, 2017 1:50 am
Thats great!! Thanks for sharing this.
vinhomesgiangvo
PostPost subject: Chung cư Vinhomes Giảng V H N&#7897
Posted: Thu Jun 29, 2017 5:09 am
Chung cư Vinhomes Giảng V H Nội khng chỉ c vị tr đắc địa cn thu ht khch hng bởi hội tụ cc tiện ch đẳng cấp bậc nhất. Xem thm chi tiết dự n tại đy: http://vinhomesgiangvohanoi148.page.tl/.
peteralan
Posted: Fri Aug 25, 2017 2:47 am
thanks, and you can add any program that will run from command line, this current batch file uses all free programs or windows built in
Gildan G185 Hoodie
Apple Support
Posted: Tue Dec 19, 2017 3:32 am
dear readers, if anyone is looking for email configuration on your device. So, you can read on Yahoo Customer Service and also can contact us for more information.
http://geekyhelp.jigsy.com/
Post new topic Reply to topic Computers OverClocked Forums - Operating Systems Page 2 of 2
No new posts Programming Guidance Resources KateBerry The General Store 0 Wed Aug 15, 2018 2:50 am View latest post
No new posts Biogenic XR - maintain your lean musc... williamtebeks Hardware/Software User Reviews 0 Tue Dec 12, 2017 3:57 am View latest post
No new posts Carhartt s line of clothing is and al... satinfabricsaa Build a Computer - Computer Building Help 0 Wed Nov 29, 2017 10:14 pm View latest post
No new posts Types of Internet Leased Line Ketzilla Internet Service Providers - ISPs 0 Fri Nov 17, 2017 3:24 am View latest post
No new posts Maintain your site new with . complily Security threats and cyber-terrorism 0 Thu Nov 16, 2017 2:55 am View latest post
