 Date/Time is Fri Feb 15, 2019 7:22 pm
Dual instances of TSC
Post new topic Reply to topic Computers OverClocked Forums - ComputersOC Distributed Computing Teams All times are GMT - 5 Hours - EDT
cbell
PostPost subject: Dual instances of TSC
Posted: Mon Mar 19, 2007 9:07 am
I'm running TSC on my home computer which has a Core2 Duo E6600. It only uses 50% of the resources (50% of each core). Should I be running two instances of the program, each set to a different affinity?
Spykill
Posted: Tue Mar 20, 2007 8:19 pm
Yes.
Jacob062406
Platinum Member
Posted: Wed Mar 21, 2007 7:15 am
Definitely yes... I run it on all 3 of my Dual Core systems... well used to until it started crapping on me!
http://www.solarice.net
http://www.vendettadesigns.com
cbell
Posted: Sat Mar 24, 2007 8:43 pm
K, cool... how do I get 2 instances to run?
Spykill
Posted: Sun Mar 25, 2007 12:28 am
Good question.
I need an answer too!
cbell
Posted: Tue Apr 10, 2007 10:02 am
No one knows? I've been using BOINC lately, only cuz it seems to be more efficiently using my resources.
PCracer51
Posted: Tue Apr 10, 2007 1:08 pm
According to: http://www.childhooddiseases.org/cgi-tsc/ultimatebb.cgi?ubb=get_topic;f=3;t=000173
To run it on a multiCPU or multicore system the easiest way is to install the community tsc software a second time to a seperate directory, and run 2 instances of the program each with a different node ID.
Also make sure to set the affinity for the processes so it used both CPUs/cores from inside task manager.
http://valid.x86-secret.com/show_oc?id=91038
cbell
Posted: Wed Apr 11, 2007 3:42 pm
Cool, thanks... I'll give it a shot when I get a chance
Spykill
Posted: Wed Apr 11, 2007 11:48 pm
Yeah, thats how I do it.
ones installed to like C:\TST
then C:\TSC\1
Posted: Thu Apr 12, 2007 12:43 am
I gotta update the guide... I just install it the first time, and then I install it a second time, but I change the path to something else... and I make sure there are two TSC icons in the startup folder, each going to the correct path (if you hit Yes for it to show up on startup on both, I think it only does it for one instance, so you need to manually put one in there).
Spykill
Posted: Thu Apr 12, 2007 9:18 am
Correctomundo.
Post new topic Reply to topic Computers OverClocked Forums - ComputersOC Distributed Computing Teams Page 1 of 1
No new posts hat is why there are instances wherei... meichangsu520 Build a Computer - Computer Building Help 0 Fri Jun 16, 2017 10:37 pm View latest post
No new posts mpionship.Durant and Westbrook have s... sxx123 Site Help and Information 0 Sat Mar 25, 2017 5:09 am View latest post
No new posts of days after the dual Brownlow medal... sxx123 Site Help and Information 0 Fri Dec 23, 2016 11:21 pm View latest post
No new posts This dazzling dual-sided charm isn't ... susanpedrowen Over Clocking and Mods 0 Thu Dec 15, 2016 3:53 am View latest post
No new posts n showed why he was the No. 1 rated d... sxx123 Site Help and Information 0 Thu Dec 08, 2016 5:16 am View latest post
