Adam His Excellency
Post subject: $99.99 - 2GB Compact Flash Elite Pro 50X, Speed 7.5MB Posted: Sun Jul 31, 2005 11:20 pm
Kingston 2GB Compact Flash Elite Pro 50X, Speed 7.5MB
http://www.outpost.com/entry?site=op:mfe072905&sku=4494426
No rebates.
Info from site:
Quote: | 2GB Compact Flash
7.5MB Transfer Rate
Design for SLR Camera
Elite Pro Series
Standardized complies with CompactFlash
Association specification standards
Small one third the size of a full-size PC card
Easy fully plug and play
Guaranteed lifetime warranty
Versatile compatible with PC Card
Type II adapters
Economical autosleep mode preserves system battery life
Compatible Windows® 98 (and newer) |
_________________ Fast computers wanted to cure diseases: Distributed Computing
Please consider upgrading to an Advantage Account. It helps the site's expensive costs. Thanks! |
