 Date/Time is Mon Aug 20, 2018 11:09 am
Unique Pages Mod help. Read here!
Goto page 1, 2 Next
Post new topic Reply to topic Computers OverClocked Forums - phpBB mods All times are GMT - 5 Hours - EDT
PostPost subject: Unique Pages Mod help. Read here!
Posted: Fri Jan 02, 2004 5:15 am
Please post which version of the Unique Pages Mod you're using when posting a thread on it. Check the older threads too to see if something was answered too if needed.
Thanks! Smile
daelin
Posted: Sat Jan 03, 2004 5:38 pm
Hi there,
I just instaled the mod, version 1.0.0 but I get a error msg.
I didn`t edit the files. I just copied them to the diretories.
Here`s the error msg I got
phpBB : Critical Error
Error updating sessions table
DEBUG MODE
SQL Error : 1054 Unknown column 'PAGE_LINKS' in 'field list'
UPDATE phpbb_sessions SET session_time = 1073165780, session_page = PAGE_LINKS, session_topic = '0' WHERE session_id = '33ce73cf7e2a0614b9127946a2f9ba91'
Line : 268
File : /home/restricted/home/subsolo1/public_html/forum/includes/sessions.php
Can you help me?
The script seams to be so cool, I really wanted to use it.
Thx in advance,
Daelin
Posted: Sat Jan 03, 2004 11:13 pm
Hello!
What other mods (if any) did you install lately?
Did you go through the steps of the mod (read the extra info for some of the steps) and make sure the files are edited like that.
What version of phpbb? What's your site too?
Thanks,
Sami
Posted: Mon Jan 05, 2004 5:15 am
Adam wrote:
Hello!
Thanks,
hi!~
its realy a cool mod
i install pafiledb n page genration time mods before this mods
but i m also facing this problem ,
my phpbb version is 2.0.6
Sami
Posted: Mon Jan 05, 2004 5:34 am
hello again
i think the main problem is with session menagment. if someone try to view direcrtly that page then he have to face that problem ,
anyone can view anypage of phpbb forum directly but can't view unique.php
Adam i m new in MODS filed , please help us in removing this problem .
Thnx!~
Sami
Posted: Mon Jan 05, 2004 5:38 am
hi
another this which i need in this forum that onle registered users can view this page ,
if gest try to view this unique page , page redirect to LOGIN.PHP.
waiting for your help
daelin
Posted: Mon Jan 05, 2004 7:29 am
Adam wrote:
Hello!
Thanks,
Hi Adam,
I don't think the problem is with other mods installed. I tried to install the unique mod in two foruns, one of them doesn't have any mod installed.
The problem is exactly the same.
I use 2.0.6 version and 2.0.4. (as I said I tested with both foruns).
Thx again,
Daelin
Posted: Mon Jan 05, 2004 8:46 am
Can you guys post a test URL that you tried it on?
Thanks.
Sami
Posted: Mon Jan 05, 2004 9:24 am
hi Adam
url is here
http://www.apnazone.com/ringing_tones.php
and i m sure i follow the installation instructions
Posted: Mon Jan 05, 2004 11:56 pm
I think I found the problem, so try doing this:
Code:
unique.php
$user_ip, PAGE_LINKS
$user_ip, PAGE_INDEX
Let me know how it works out!
Thanks,
Sami
Posted: Tue Jan 06, 2004 1:45 am
Hi Adam,
its working now
Thnx
Posted: Tue Jan 06, 2004 2:01 am
Anytime! Feel free to register here at computersOC too. We have some other forums to check out if/when needed. Smile
Thanks,
Sami
Posted: Tue Jan 06, 2004 6:29 am
hi Adam,
Adam i want only registered users can view unique mods.
if any guest this page it rediect to login.php page
waiting for help
--------{Sami}----------
Posted: Tue Jan 06, 2004 8:43 am
I will look in to that and let you know.
Thanks,
Daelin-loggedout
PostPost subject: Thx!
Posted: Tue Jan 06, 2004 9:33 pm
Hi Adam,
I just tested, and now it works.
Thank you, very much, for making the script and helping us.
Daelin
Posted: Fri Jan 09, 2004 8:45 am
Sami wrote:
hi Adam,
waiting for help
Code:
http://www.yourdomain.com/login.php?redirect=/YOURPAGEADDRESS.php
if your domain has a folder after it, ie. http://www.computersoc.com/something the link would look like http://www.computersoc.com/something/login.php....
http://www.computersoc.com/login.php?redirect=/tos.php - Try that for example.
Posted: Mon Mar 08, 2004 5:56 am
ok i installed it how it said... now what do i do? what page do i go to?
Posted: Mon Mar 08, 2004 8:42 am
Welcome to computersOC! You should register!
Go to whatever you named the php file (wherever you put it). It should tell you everything to do in the mod.
scda88
PostPost subject: Re: Unique Pages Mod help. Read here!
Posted: Wed Aug 11, 2004 7:28 pm
No scroll bars. I installed this mod, works great. Only problem, my scroll bars disappeared... Any help? Thanks, jon.
Posted: Thu Aug 12, 2004 2:47 am
Can you give a link to the page? What version of phpBB?
funny-bunny
Posted: Fri Aug 27, 2004 9:29 am
Adam wrote:
Sami wrote:
hi Adam,
waiting for help
Code:
Where do i put that code:
Code:
As a link so when they are logged in they can view and when they aren't logged in they get redirect?
Please help me...
Posted: Fri Aug 27, 2004 12:50 pm
In overall_header.tpl you will put this:
Code:
<!-- BEGIN switch_user_logged_out -->
<!-- END switch_user_logged_out -->
<!-- BEGIN switch_user_logged_in -->
http://www.yourdomain.com/YOURPAGEADDRESS.php
<!-- END switch_user_logged_in -->
Making both URLs above to whatever the link is (use html).
Relentless
Posted: Sun Apr 24, 2005 4:13 am
Agh! I added a 2nd page and then this happens:
Quote:
Parse error: parse error, unexpected T_INCLUDE in /var/www/html/boards/about.php on line 21
Here is my code...
Code:
<?php
define('IN_PHPBB', true);
$phpbb_root_path = './';
include($phpbb_root_path . 'extension.inc');
include($phpbb_root_path . 'common.'.$phpEx);
// Start session management
$userdata = session_pagestart($user_ip, PAGE_INDEX);
init_userprefs($userdata);
// End session management
// Output the basic page
$page_title = $lang['About']
include($phpbb_root_path . 'includes/page_header.'.$phpEx);
$template->set_filenames(array(
'body' => 'about.tpl')
make_jumpbox('viewforum.'.$phpEx);
$template->pparse('body');
include($phpbb_root_path . 'includes/page_tail.'.$phpEx);
Posted: Sun Apr 24, 2005 9:33 am
Welcome! Smile
Can you post the contents of about.tpl?
Thanks!
Relentless
Posted: Sun Apr 24, 2005 9:36 am
Code:
<style type="text/css">
p {
font-family: "Trebuchet MS", "Times New Roman";
font-size: 15px;
font-style: normal;
line-height: normal;
font-weight: normal;
font-variant: normal;
h3 {
font-family: Arial, Helvetica, sans-serif;
font-size: large;
</style>
<h3>About Qwerty Games</h3>
<p><font face="Georgia, Times New Roman, Times, serif">Qwerty Games was founded in the start of the year 2005. January 5th 2005 while I was looking for a name to put all my games in. Qwerty Games was a nobody back then becuase penguins didn't exist. Yes I know it's a shame that penguins didn't exist back then, only until the February the 2ndcame back. Qwerty Games gained popularity in mid-February and people just came to the forums to talk to each other I think. That's all from the great Relentless :)</font></p>
<p><font face="Trebuchet MS, Times New Roman"><a href="http://www.qwertygames.net/boards">Back to Qwerty Games</a></font></p>
Try and please leave the copyright information at the bottom of your page for our mod.
It's the link for our support page for the mod anyway. :)
<p>
Page created using <a href="http://www.computersoc.com/viewforum.php?f=60">Unique Pages Mod</a>.
I'm a load of crap okay!?
</p><BR>
Post new topic Reply to topic Computers OverClocked Forums - phpBB mods Page 1 of 2
Goto page 1, 2 Next
No new posts Is the Kindle Fire good to read on? blakejones Hardware/Software User Reviews 1 Tue Jun 12, 2018 7:59 am View latest post
No new posts sword art online game, Enjoy so Uniqu... simbasmiths Gaming 1 Thu Mar 22, 2018 5:40 am View latest post
No new posts India unique charm in the near long run fadbxv Hardware/Software Help, Questions and Information 0 Tue Feb 06, 2018 4:13 am View latest post
No new posts Unique features that make QuickBooks ... quickbooktech247 Hardware/Software Help, Questions and Information 0 Mon Jan 22, 2018 3:43 am View latest post
No new posts never miss to participate Jollyhers U... jollyhersblog Broadband Tweaks, Tips and Optimization 0 Thu Jan 11, 2018 4:15 am View latest post
