 Date/Time is Fri Feb 15, 2019 7:25 pm
How to setup Time Machine with my NETGEAR router?
nicolesmithus
PostPost subject: How to setup Time Machine with my NETGEAR router?
Posted: Fri Jul 13, 2018 3:07 am
Hi,
I have a wifi router but I have some problems related to this. So I want the solution. Please tell me, How to set up Time Machine with my NETGEAR router?
Give me a valuable suggestion.
Thank You
nataliasimmons
PostPost subject: Re: How to setup Time Machine with my NETGEAR router?
Posted: Fri Jul 13, 2018 7:59 am
Hi,
Follow it for setup Time Machine with my Netgear Router.
Step 1: Physically connect the USB hard drive to your Mac.
Step 2: On your Mac, go to Spotlight (or the magnifying glass) located at the top right of the screen and search for Disk Utility.
Step 3: Open the Disk Utility and format your drive, as shown here.
Note-1: The NETGEAR router only supports GUID and MBR partitions. To see how to change the partition scheme, please see "Changing the Partition Scheme" at the bottom part of this page.
Note-2: We suggest using a new USB HDD or formatting your old USB disk to do the Time Machine backup for the first time. Use a blank partition to prevent some issues during backup using Time Machine.
Step 4: Unplug the USB hard drive from your Mac and connect it to the router.
To access the connected USB hard drive from your Mac or PC:
On a Mac: Go > Connect to Server >type: smb: //readyshare
On a PC: Start > Run > type: \\readyshare
Step 5: In the pop-up window, select Registered User, and enter admin as the username and password as the password. Click Connect.
mywifiext net | www mywifiext net setup wizard | mywifiext
No new posts How to Recover Deleted Files from Tim... MrJude Hardware/Software User Reviews 0 Mon Dec 17, 2018 11:50 pm View latest post
No new posts Johnny Manziel finally details the time sherry2018love Site Help and Information 0 Sun Oct 21, 2018 10:56 pm View latest post
No new posts netgear support number +18559000490 ashutoshweb3 Site Bugs 0 Tue Aug 14, 2018 7:12 am View latest post
No new posts Router support number +18559000490 ashutoshweb3 Site Bugs 0 Tue Aug 14, 2018 7:11 am View latest post
No new posts IT'S time to stock up on Pandora char... barbaraland Site Bugs 0 Mon Aug 13, 2018 2:55 am View latest post
