 Date/Time is Thu Jul 19, 2018 9:05 pm
Ivy Bridge Temperatures Its Gettin Hot in Here
Passivation purpose and method of stainless steel pipe
PostPost subject: Passivation purpose and method of stainless steel pipe
Posted: Thu Jun 14, 2018 4:21 am
Usually the stainless steel pipe as the water supply pipeline before, in the process there will be a passivation process, its purpose is to protect the formation of chromium oxide coating on the inner wall of stainless steel pipe with smooth surface, so that it can resist high temperature of liquid on the surface of stainless steel may produce intergranular corrosion.
One of the commonly used formulations of passivation treatment is the use of purified water and chemical pure nitric acid to become 8% of the acid solution. Circulation at 49 to 52 degrees centigrade after 60 minutes. 8%, the role of nitric acid is mainly until the action of oxidant. The surface of stainless steel is oxidized to nitric oxide, so that it can achieve the purpose of passivation. The manufacturer is not usually stainless steel passivation, all processors to do. For the passivation water pipe, the stainless steel pipe must be polished both inside and outside, and the inner surface of the pipe must be passivated.
The whole passivation process of stainless steel pipes includes cleaning, passivation and disinfection. The main processes are deionized water circulation pre flushing, alkaline solution cycling cleaning, purified water washing, passivation, purified water washing, discharging and pure steam disinfection.
The first is the purified water flushing, a liquid storage tank and a water pump in advance and passivation of the water supply pipeline into a circulating passage, injecting deionized water at room temperature enough in the liquid storage tank, the use of pumps for circulation, open the drain valve in 15 minutes, while circulating emissions, the best put a meter.
The next is alkali cleaning, prepare sodium hydroxide, chemical reagent and add hot water to make 1% of the lye in advance, then use the pump to do the cycle. The time is no less than 30 minutes, then it will be discharged again.
Next is to rinse, add purified water to the liquid storage tank, start the pump and open the drain valve to discharge, until the electrical resistivity of each outlet is consistent with that of the water in the tank, and the emission time is longer than 30 minutes.
The following is the passivation procedure, can use the purified water and nitrate with chemical pure acid in a concentration of 8%, 60 minutes after the discharge cycle at 49 DEG -52 DEG C; using 3% or 20% hydrofluoric acid, nitric acid and 77% water purification solution, solution temperature control at 25-35 DEG C, cycling 10-20 minutes then discharge, finally through high pressure steam to flush the water supply pipeline to remove the dirt.
The flushing is divided into initial washing and final rinsing. The former is rinsed at room temperature, and the time is more than 5 minutes. The latter requires that the electrical resistivity of import and export ionic water should be consistent.
Source: China Stainless Steel Pipelines Manufacturer - Yaang Pipe Industry Co., Limited (www.yaang.com)
PostPost subject: Re: [討論]宮廷牌
Posted: Tue Jul 10, 2018 2:41 am
クロムハーツ
mulberry uk
tods outlet
nike requin pas cher
pandora
pandora jewelry outlet
new nike shoes
huaraches
ralph lauren uk
ugg boots clearance
ugg boots clearance
pandora charms outlet
canada goose jackets
nike factory store
jimmy choo outlet
ray ban eyeglasses
polo ralph lauren
nike soldes femme
nike blazer pas cher
ralph lauren uk
ralph lauren uk
air jordan 8
off white jordan 1
moncler online outlet
manolo blahnik outlet
pandora
ray ban eyeglasses
manolo blahnik
nike air max 95 ultra
polo lacoste
nike factory store
golden goose shoes
nike presto femme
oakley sunglasses wholesale
pandora outlet
off white outlet
moncler
ralph lauren uk
ugg boots on sale 70% off
ed hardy uk
true religion outlet store
adidas football soldes
jordan 8
polo ralph lauren
ralph lauren uk
christian louboutin sale
superdry clothing
nike presto
off-white clothing
salomon
tory burch handbags
pandora
ugg boots clearance
ugg boots clearance
supreme shirt
manolo blahnik shoes
michael kors outlet clearance
ralph lauren uk
ray ban eyeglasses
pandora
nike air jordan
air jordan uk
nike shoes for women
ralph lauren uk
pandora outlet
ugg boots clearance
ugg boots clearance
pandora
nike huarache femme
off white
ugg boots clearance
ralph lauren uk
moncler online
tn pas cher
jordans
soccer shoes
supreme outlet
pandora
nike air max 95
red bottom
bottega
ugg boots clearance
dsquared
reebok
vibram fivefingers shoes
nike shoes for men
ferragamo shoes
off white shoes
polo ralph lauren
canada goose
supreme new york
moncler uk
off white clothing brand
basket nike femme
giuseppe zanotti
nike factory
jordans
ugg boots clearance
hugo boss sale
off-white clothing
nike chaussure
jimmy choo shoes
issey miyake perfume
bottega veneta
off white clothing
mbt
supreme shirt
prada shoes
polo ralph lauren
off white nike
ralph lauren uk
ecco shoes
pandora outlet
giuseppe zanotti sneakers
cheap nhl jerseys
red bottom
louboutin outlet
skechers shoes
fitflops shoes
skechers outlet
off white clothing
super dry
michael kors outlet online sale
cheap ray bans
mlb shop
ralph lauren uk
salomom shoes
converse trainers
hugo boss outlet
off white jordan 1
mbt shoes outlet
valentino shoes
pandora
ugg boots uk
nhl jerseys wholesale
ralph lauren uk
football pas cher
hermes belts
ultra boost 3.0
prada shoes
maillot football pas cher
ecco outlet
nike soldes
cheap snapbacks
football soldes
nike outlet store
dsquared2
salomom shoes
moncler online
dsquared
basket nike
ugg boots clearance
ralph lauren uk
soccer boots
jordans
ed hardy clothing
air jordan 4
pandora
ray ban eyeglasses
golden goose shoes
nike tn pas cher
mbt shoes
ferragamo outlet
off white shoes
ugg boots clearance
nike outlet store
moncler online
dsquared2
nike blazer
saics running shoes
nike requin
adidas superstars
canada goose uk
nike chaussure femme
issey miyake
fitflops sale
pandora
mbt shoes
nike factory outlet
salomon
moncler online
nike factory outlet
tods shoes
pandora
canada goose uk
valentino
mulberry handbags
fitflops sale
snapbacks wholesale
No new posts Specification and application of stai... yaangcom The General Store 0 Thu Jul 19, 2018 5:58 pm View latest post
No new posts characteristics of stainless steel se... yaangcom The General Store 0 Tue Jul 17, 2018 10:00 am View latest post
No new posts Two forms and application examples of... yaangcom The General Store 0 Mon Jul 16, 2018 10:34 am View latest post
No new posts surface treatment process for stainle... yaangcom The General Store 0 Sun Jul 15, 2018 10:09 am View latest post
No new posts Strength difference of various kinds ... yaangcom The General Store 0 Wed Jul 11, 2018 7:50 pm View latest post
