 Date/Time is Fri Jan 18, 2019 4:12 pm
How to solve the hbo go activation problem on apple tv?
activatehbo
PostPost subject: How to solve the hbo go activation problem on apple tv?
Posted: Mon Mar 26, 2018 2:21 am
Hello Friends,
I'm getting the HBO Activation issue while activating the HBO go service on my Apple TV. Is there any way to fix the HBO Go Activation problem. Please Suggest me.
Thanks
nataliasimmons
PostPost subject: Re: How to solve the hbo go activation problem on apple tv?
Posted: Mon Mar 26, 2018 3:34 am
Hello,
Step 1: Restart the HBO GO app
Double tap the home button on your remote.
Tap and swipe HBO GO up and off the screen to close it.
From the Home screen, choose HBO GO to restart the app.
Try signing in to your Apple TV. If you still can't, move onto the next step.
Step 2: Restart your Apple TV
Restart your Apple TV by navigating to Settings > System > Restart.
Step 3: Update your Apple TV software
Make sure that your Apple TV software is up to date by navigating to Settings > System > Software Updates.
Step 4: Delete and reinstall HBO GO
From the Home screen, move the selection to the HBO GO app.
Press and hold the Touch surface for two seconds and then press the Play/Pause button.
Choose Delete.
Go to the App Store to reinstall HBO GO.
Step 5: Reset your Apple TV
Reset your Apple TV by navigating to Settings > System > Reset & Update.
hbo go comcast | hbo go roku | hbo go apple tv | www hbogo comactivate
activatenetflix
Posted: Mon Mar 26, 2018 5:15 am
Hi,
Following These Steps:
Step 1: Uninstall/Reinstall the HBO GO app
Uninstall the HBO GO app, then reinstall it from the app store. Then try activating your Apple TV again. If you still can't, move onto the next step.
Restart the device by going to Settings > General > Restart. If you can't restart your Apple TV because it's unresponsive, try the following:
1. Hold down Menu and Down on the Apple Remote for six seconds, and then release when you see the indicator light on the Apple TV blink rapidly.
2. Unplug the Apple TV power cord for three seconds, and then plug it back in.
Try activating your Apple TV again. If you still can't, move onto the next step.
Step 3: Clear cache, restart, and check for updates
1. Clear the cache on the Apple TV by holding down the Menu button for 10 seconds.
2. Turn your Apple TV off, then turn it back on again.
3. Install any available Apple TV software updates.
Step 4: Reset your Apple TV
HBO Go Customer Service Phone Number | HBO Go Roku Activate | HBO Go Activate Device
activatehbo
Posted: Thu Apr 26, 2018 3:04 am
Hi,
Thanks for giving valuable solution. All giving solution are working good and my problem is solved out. Thanks friends your's knowledge help me.
HBO Go Activation | HBO Go Activate Roku
No new posts Amazon Fire TV Sound Problem foster4 Request New Features 0 Thu Dec 20, 2018 4:03 pm View latest post
No new posts Epson Printer Problem adv2016 Hardware/Software Help, Questions and Information 0 Fri Oct 26, 2018 2:59 am View latest post
No new posts No Peyton Manning no problem Troy Aikman sherry2018love Site Help and Information 0 Tue Sep 18, 2018 12:11 am View latest post
No new posts Apple support number +1-855-553-4777 ashutoshweb3 Site Bugs 0 Tue Aug 14, 2018 7:09 am View latest post
No new posts problem in to login email xiaozhengm ComputersOC Distributed Computing Teams 3 Tue Jul 17, 2018 6:53 am View latest post
