 Date/Time is Thu Jan 24, 2019 4:56 am
How do I set up my Orbi router and satellite?
nicolesmithus
PostPost subject: How do I set up my Orbi router and satellite?
Posted: Thu Feb 01, 2018 3:05 am
Hello Friends,
Recently I buy a new Orbi router and I don't know how to setup it. If anyone knows how setup it please tell me
activatehbo
PostPost subject: Re: How do I set up my Orbi router and satellite?
Posted: Fri Feb 02, 2018 3:30 am
Hello,
To set up your Orbi router and satellite:
1. Unplug your modem and remove and replace the backup battery if it uses one.
2. Plug the modem back in.
3. Connect your modem to the yellow Internet port on your Orbi router using the included Ethernet cable.
4. Connect your Orbi router to a power source.
Note: If the Power LED on the back of the Orbi router does not light, press the Power On/Off button.
5. Wait for the Orbi router's ring LED to light solid white and then pulse white.
6. Place the Orbi satellite in the middle of your house to get the best WiFi coverage.
7. Connect the Orbi satellite to a power source.
Note: If the Power LED on the back of the Orbi satellite does not light, press the Power On/Off button.
8. Wait for the Orbi satellite's ring LED to light solid white, then pulse white, and then pulse magenta.
Note: The Orbi satellite's ring LED might pulse magenta for up to one minute while the satellite attempts to sync with the Orbi router.
9. After the Orbi satellite's ring LED pulses magenta, it lights one of the following colors for 10 seconds then turns off:
o Solid blue. The connection between the Orbi router and Orbi satellite is good.
o Solid magenta. The Orbi satellite cannot connect to the Orbi router. Move the Orbi satellite closer to the Orbi router.
o Solid amber. The connection between the Orbi router and Orbi satellite is fair. Consider moving the Orbi satellite closer to the Orbi router.
Note: If the Orbi satellite's ring LED is still pulsing magenta after about one minute, and you already moved the Orbi satellite closer to the Orbi router, press the Sync button on the Orbi router and on the Orbi satellite.
If the Orbi satellite successfully syncs with the Orbi router, the Orbi satellite's ring LED pulses white, then lights solid blue to indicate a good connection, and then turns off.
10. Connect your computer or mobile device to the Orbi router or satellite with an Ethernet or WiFi connection.
Note: To connect with WiFi, find the preset WiFi network name (SSID) and password on the label on the Orbi router or satellite and connect to that network from your WiFi-enabled computer or mobile device.
11. Visit http://orbilogin.com and follow the on-screen instructions to set up your Orbi network.
The Orbi router's ring LED turns off after the setup is successfully complete.
mywifiext | www mywifiext net login | mywifiext net login
No new posts Router support number +18559000490 ashutoshweb3 Site Bugs 0 Tue Aug 14, 2018 7:11 am View latest post
No new posts How to setup Time Machine with my NET... nicolesmithus Site Help and Information 1 Fri Jul 13, 2018 3:07 am View latest post
No new posts D-Link router customer help support n... triptivms ComputersOC Distributed Computing Teams 0 Fri Apr 13, 2018 3:00 am View latest post
No new posts el método correcto de conexión entre ... wangyueyue Site Help and Information 0 Thu Apr 12, 2018 10:25 pm View latest post
No new posts The Citizen Mens Eco-Drive Satellite yanzhongr5 Gaming 0 Mon Jan 22, 2018 11:24 pm View latest post
