 Date/Time is Tue Jan 22, 2019 12:52 pm
Extreme room temperatures are harmful.
Post new topic Reply to topic Computers OverClocked Forums - Hardware/Software User Reviews All times are GMT - 5 Hours - EDT
Bourque-zise
PostPost subject: Extreme room temperatures are harmful.
Posted: Tue Sep 27, 2016 11:20 pm
It can sometimes be difficult to know how to clean your cherished collectible without causing harm. The following is a simple guideline for you to help you learn which way is the best way to care for your doll. Porcelain Dolls: With porcelain nike juvenate uomo , the decorations are usually fired on, so it would be unlikely that that you would hurt them by cleaning. Use warm soapy water. If this doesn't work good enough, try a wet eraser to remove marks. As a last resort, very, very gently clean with a low abrasive cleaner such as Tilex or Soft Scrub. Use caution because some cleansers have bleaching agents that could be devastating to antique clothing, wigs or bodies. Ultra violet rays can be very damaging to porcelain dolls air jordan italia shop , so when you are displaying your doll, avoid direct sunlight. Celluloid Dolls: These dolls are extremely perishable. They are easily broken and can become very brittle over time. Proper care and respect of a celluloid doll helps a perfect example remain in that condition. Heat is celluloid's worst enemy. Keep these dolls in a cool room with good ventilation - and never store celluloid in a sealed case - it can combust! Cloth Dolls: Vintage cloth dolls can be worth thousands of dollars and deserve your best efforts to preserve them and prevent needless deterioration. Keeping the fabric clean is important because it's exposing the fabric to pollutants that will weaken the material. Direct sunlight is not good for these dolls. You should also inspect your cloth dolls every now and then for insects. There are insecticides designed especially for textiles under many brands and the results can be excellent if used according to instructions. If you decide to vacuum your doll, place a nylon screen over the fabric first to protect the delicate fibers. Most often, a good vacuuming is enough to restore a doll to display condition. If you doll is badly soiled, get the advice of a professional who specializes in preserving textiles. Sometimes you can use an eraser or art gum, tapeten and reinger-and-absorene to clean your cloth doll. These seem to give the best results. Ink can be removed with hairspray air jordan retro italia , but first test an area on the doll to assure that no damage will occur. Apply the hair spray with a cloth, and wipe in a light rubbing motion with a clean white cloth. For display purposes, it is best to keep them in protective cases and inspect them regularly. Moth crystals should be placed near your dolls. Many collectors recommend making a small cloth pouch, filling it with moth crystals and placing it under the doll's hat or tying it around its waist beneath the clothing. Composition and paper-mache Dolls: These dolls pretty much require the same care as the cloth type dolls. They are especially susceptible to damage from temperature changes. Never store composition or paper-mache dolls in a hot or cold attic, or in a damp basement. Most collectors will accept some signs of aging on composition dolls - fine craze lines or cracked eyes, for example. There are many popular ways for cleaning composition nike air yeezy 2 rosse , but first always test it on an inconspicuous area of the doll and work quickly - never leave any cleaning agent on the doll for any length of time. Pond's Cold Cream or Vaseline and a soft tissue work well for these dolls. Another option is paste window cleaner but not the ammonia type. You want the old fashioned paste that you can get at most hardware stores. Wigs can be restyled after spraying with Johnson's & Johnson's No More Tangles. Faded or worn-off facial features can be touched up with artist's colored pencils. When moistened, they are very easy to apply. Crackled eyes are best left alone. Hard Plastic Dolls: These types of dolls are very resilient and can be cleaned with almost any soap detergent. You can clean stubborn stains with cold cream or waterless hand cleaner. Avoid chlorine, bleach and ammonia. Never use fingernail polish remover or lacquer thinner which may eat into the plastic! You can use Oxy-10 to remove stains that are not close to painted surfaces. Just moisten a cotton ball and allow it to sit on the stain for several hours. You may have to repeat this process several times. After each cleaning, wash the doll with mild soap and rinse well. For displaying purposes, avoid direct exposure to ultraviolet light. Although they may seem indestructible, hard plastic can slowly oxidize and change color and direct heat can also cause warping. Rubber Dolls: These dolls will deteriorate no matter what precautions you take nike air yeezy 2 italia , but you can delay the process. Any form of grease is harmful and accelerates deterioration. If you have a "Magic Skin Doll" always wear cotton gloves when handling her. Rubbing corn starch on these kinds of dolls twice a year will help to preserve the dolls' life. Maintain an even temperature and avoid changes in humidity. Tin Dolls: These dolls often have chipped paint which can happen from the metal getting cold which in turn causes the paint to lift off the face. Try to keep these dolls in a constant temperature environment. Vinyl Dolls: Vinyl dolls are probably the most lifelike in appearance and touch. In order to keep them looking that way, special care is needed. Extreme room temperatures are harmful. Even quality vinyl dolls subjected to heaters or air conditioners can be damaged in just a few months. Direct sunlight can be deadly. Vinyl is also sensitive to fluorescent light; use indirect non-fluorescent lights. Finally, avoid tightly sealed show cases or glass domes because condensation can form and damage vinyl dolls. Wooden Dolls: Chipping paint is a major problem with wooden dolls. Humidity and mistreatment are the two main culprits. Keep wooden dolls in a dry atmosphere. Expanding and contracting associated with high humidity causes paint to chip.
Post new topic Reply to topic Computers OverClocked Forums - Hardware/Software User Reviews Page 1 of 1
No new posts Escape Room Props - Buy The Best Prop... robinyakov Gaming 0 Thu Nov 01, 2018 11:46 pm View latest post
No new posts https://votofelforcefinland.com/celur... jeje222 Site Help and Information 1 Wed Jan 24, 2018 3:22 am View latest post
No new posts http://www.leuxiaavis.fr/celuraid-ext... davidpoirier1 Site Help and Information 0 Sat Dec 16, 2017 3:56 am View latest post
No new posts http://supplementaustralia.com.au/cel... pedrocurd1 Site Help and Information 0 Thu Dec 14, 2017 5:00 am View latest post
No new posts http://trimcoloncleanse.dk/celuraid-e... Nutralu Garcinia Operating Systems 1 Wed Dec 13, 2017 5:03 am View latest post
