| Author |
Message |
Krow147 NEW POSTER
Post subject: Newly Built Computer Won't Power On, PSU Beeps Posted: Fri Feb 05, 2010 3:17 am
I just finished building a computer, but it won't turn on. When the PSU is powered on and the lead is connected to the mobo it beeps quickly, and shows no signs of power. I tested the PSU on another computer and it worked fine with no odd beeping. And it's the PSU beeping, not the mobo.
Parts: Gigabyte GA-MA785GM-US2H Mobo,
Ultra LSP550 PSU
8GB Corsair XMS2 RAM
AMD Phenom II X4 955
| Back to top
Adam His Excellency
Post subject: Posted: Fri Feb 05, 2010 9:42 am
Welcome to computersOC!
Do you have both connectors plugged into the motherboard, and one or two plugged into your video card?
Do any fans spin up?
_________________ Fast computers wanted to cure diseases: Distributed Computing
Please consider upgrading to an Advantage Account. It helps the site's expensive costs. Thanks! |
| Back to top
Krow147 NEW POSTER
Post subject: Re: Newly Built Computer Won't Power On, PSU Beeps Posted: Fri Feb 05, 2010 1:41 pm
| Both connectors are plugged in to the mobo, and one is connected to my video card. No fans spin up.
| Back to top
Adam His Excellency
Post subject: Posted: Fri Feb 05, 2010 6:35 pm
| Unhook everything and unscrew the motherboard from the case. Start over and hook everything back up but this time with minimal items. No extra pci cards, only one RAM stick, etc.
| Back to top
Krow147 NEW POSTER
Post subject: Re: Newly Built Computer Won't Power On, PSU Beeps Posted: Fri Feb 05, 2010 6:44 pm
| Alright, it works now. I think I have the information I need to get it running. Thanks
| Back to top
Adam His Excellency
Post subject: Posted: Fri Feb 05, 2010 7:46 pm
| What did you do to get it to work?
| Back to top
Krow147 NEW POSTER
Post subject: Re: Newly Built Computer Won't Power On, PSU Beeps Posted: Fri Feb 05, 2010 9:25 pm
| I took everything out of the case and removed the unneccasary components, even with all of them attached it works outside the case. I'm assuming this means that the case was shorting the motherboard out.
| Back to top
Adam His Excellency
Post subject: Posted: Fri Feb 05, 2010 11:32 pm
| It's possible. Sometimes taking the motherboard out and putting it back in will help, some cable could have been overlooked or a part might not have agreed with the setup.
| Back to top
| View previous topic :: View next topic |
