 Date/Time is Sat Feb 16, 2019 9:39 am
How do I reset my n300 WiFi range extender?
nicolesmithus
PostPost subject: How do I reset my n300 WiFi range extender?
Posted: Fri Jun 22, 2018 6:06 am
Hi there,
I have a wifi but some problem related to about it. So I want to know more than. Now please tell me about, How do I reset my n300 WiFi range extender?
Give me a valuable suggestion related to this.
Thank You
nataliasimmons
PostPost subject: Re: How do I reset my n300 WiFi range extender?
Posted: Fri Jun 22, 2018 7:40 am
To connect the NETGEAR WiFi Extender manually:
If you have a NETGEAR WiFi Extender with an Ethernet port (EX6100, for example):
Use a computer to connect to NETGEAR WiFi Extender via Ethernet cable.
Login to the web user interface of your NETGEAR WiFi Extender using http://myWiFiext.net.
You will be prompted to enter a username and password.
Default login credentials are:
Username: admin
Password: password
Note: Username and password are case sensitive.
Once you have successfully logged in, go to Setup > Wireless Settings.
Check the value in the Password (Network Key) field under Security Options.
If the password is not same as your router password, change it so it matches.
Click Apply.
Reconnect your Wi-Fi devices to the NETGEAR WiFi Extender.
www.mywifiext.net | www mywifiext net | www mywifiext net setup | mywifiext net
No new posts IT'S time to stock up on Pandora char... barbaraland Site Bugs 0 Mon Aug 13, 2018 2:55 am View latest post
No new posts How to do Factory reset of Wireless A... activatehbo The General Store 3 Tue Apr 17, 2018 5:01 am View latest post
No new posts How does the computer create a WiFi h... wangyueyue Site Help and Information 0 Sun Mar 18, 2018 11:50 pm View latest post
No new posts Recover Or Reset Your Facebook Passwo... xiaozhengm Hot Deals 12 Sun Mar 11, 2018 2:38 am View latest post
No new posts The best range of gaming,laptop, desk... emilywhite Broadband Tweaks, Tips and Optimization 0 Thu Jan 18, 2018 4:17 pm View latest post
