 Date/Time is Sun Jun 24, 2018 10:42 am
How to use the bottom welder in stainless steel pipe welding
PostPost subject: How to use the bottom welder in stainless steel pipe welding
Posted: Tue May 22, 2018 10:41 am
The process of welding stainless steel pipe usually consists of three kinds of soldering, filling and cover welding. The backing welding is the most important part of the stainless steel tube welding process, which is related to the quality and progress of the project. It includes two processes: back filling argon and not argon filling. The backside argon filling protection is also divided into two kinds: solid core wire plus TIG process, solid core wire plus TIG and water soluble paper technology, while the back without argon protection is also divided into two kinds: flux cored wire backing welding, welding rod bottom welding and TIG welding.
The use of stainless steel backing welding method is TIG process, according to the actual situation, can have the following four ways to do the backing welding processing, respectively by using the method of blocking back sealing plate ventilation protection; the second is only using soluble paper or combined with the method of blocking protection ventilation using soluble paper and blocking plate the use of TIG base cored wire; welding; use of flux cored wire TIG welding backing.
The first is the use of the back blocking method for sealing plate ventilation protection, in prefabricated stainless steel pipe, welding need to do rotary welding, are usually easier, this method is generally used for blocking plate pipe welding on both sides of the mouth to block the ventilation protection of backing welding at the same time, the outer side of the adhesive used cloth plugging.
When welding, to use the advance, lag process gas, lateral adhesive selvage welding edge tear, because the blocking plate is composed of rubber and tin, is not easy to damage, so that the welding process can ensure good weld inside filled with argon and ensure its purity, in order to effectively ensure the weld metal is not inside oxidation, ensure the quality of weld backing welding.
The second is to use only soluble paper or the combination of soluble paper and plugged plate for blocking ventilation protection. Because when stainless steel pipes are fixed and welded, the inside ventilation is difficult, and some sides are easier to block. In such cases, water soluble paper and blocking plate can be used for plugging. That is to say, one side is easy to ventilate and dismantle, and the side is blocked by blocking plate, and it is not easy to ventilate. It is difficult to remove the side of the blocking plate and use water soluble paper to do the plugging. And the outer side is glued with cloth to paste the weld line for plugging.
Stainless steel fixed mouth in welding, weld on both sides have not ventilation in most cases of the phenomenon, how to ensure that the inner weld argon protection is a difficult problem, in actual construction, the use of both sides of the weld of water soluble paper plugging, pass gas, from the weld center outside the use of adhesive cloth paste do plugging this method can effectively solve the above problems.
When water soluble paper is used to plug and ventilate, because it is ventilated from the weld center, in the final sealing part, we need to quickly insert the vent pipe, and use the remaining argon inside to protect it, and quickly finish the bottom and seal the mouth.
Using this approach, we should pay attention to water soluble paper to use double, need is stuck, or will cause water soluble paper damage loss and the inside of the weld without the protection of argon, oxidized, cause the weld cut re welding, which can not guarantee the welding quality, and has seriously affected the period. Therefore, before welding should strictly check, paste the water soluble paper.
In most construction sites, this welding method is usually used to make the bottoming. Its quality can be obviously guaranteed, and at the same time, there is still a certain degree of difficulty in construction. Therefore, a careful and skilled welder is needed to do this work.
The third way is not to carry out argon protection on the back, using flux cored wire plus TIG technology. This method has been used for many years in China, and the corresponding products have been used in the field welding, which has achieved relatively good economic benefits.
Because the back is not filled with argon, its advantages are also very obvious, the main performance is high efficiency, convenience, low cost, suitable for installation in the construction site. However, because of its structural characteristics, the flux cored wire has high requirements for welders. The wire feeding speed is fast and the accuracy of wire feeding is also very high. It is difficult to master fully. The welders should be trained by special training and skilled.
The last one is the back without argon protection, the use of flux cored wire with TIG process, in the last century in 90s, Japan's Kobelco and other companies developed grounding wire, and all these years has been developed and applied in the grounding wire of stainless steel in the actual construction, obtained very good effect.
The protection mechanism of this process is to protect the weld metal from molten slag formed by welding wire and metallurgical reaction of other alloying elements on the back weld. The frontal weld is protected by argon, slag and alloying elements.
Source: China Stainless Steel Pipes Manufacturer - Yaang Pipe Industry Co., Limited (www.yaang.com)
No new posts Factors affecting the wall thickness ... yaangcom The General Store 0 Thu Jun 21, 2018 6:15 am View latest post
No new posts Connection methods of stainless steel... yaangcom The General Store 0 Wed Jun 20, 2018 8:37 am View latest post
No new posts adding titanium in austenitic stainle... yaangcom The General Store 0 Tue Jun 19, 2018 9:29 am View latest post
No new posts Market Trajectory Of Global Stainless... Sebahtstian Hardware/Software Help, Questions and Information 0 Tue Jun 19, 2018 3:20 am View latest post
No new posts solid solution processing for stainle... yaangcom The General Store 0 Mon Jun 18, 2018 10:23 am View latest post
