 Date/Time is Fri Jul 20, 2018 8:09 pm
The head size reducing process
flanges
PostPost subject: The head size reducing process
Posted: Tue Jun 21, 2016 6:40 pm
Concentric reducer should not have crack, double skin appearance, wall thickness should be greater than the big diameter end section of the wall thickness. Roundness of eccentric reducer should not be greater than 1% of the corresponding end diameter, and the allowable deviation of plus or minus 3 mm; Centerline should overlap on both ends of the concentric reducer, the eccentric value allowable deviation is + / - 5 mm.
Size reducing forming technology of the head is with the head big end diameter equal to the size of the pipe into the forming die, along the axial direction of tube billet by pressing, shrink along the cavity movement and metal forming. Head size should not have crack, double skin appearance, wall thickness should be greater than the big diameter end section of the wall thickness.
Centerline should overlap on both ends of the concentric reducer, the eccentric reducer value allowable deviation is + / - 5 mm. According to the size of the reducer, divided into the one of pressing or more press forming.
Source: Zhejiang Yaang Pipe Industry Co., Limited (www.yaang.com)
No new posts surface treatment process for stainle... yaangcom The General Store 0 Sun Jul 15, 2018 10:09 am View latest post
No new posts welding process of the duplex stainle... yaangcom The General Store 0 Sat Jun 16, 2018 11:55 pm View latest post
No new posts Surface treatment process of stainles... yaangcom The General Store 0 Tue Jun 12, 2018 8:14 am View latest post
No new posts Operation process of stainless steel ... yaangcom The General Store 0 Mon Jun 11, 2018 6:08 am View latest post
No new posts Global Ball Bearings Market Share and... Sebahtstian Hardware/Software Help, Questions and Information 0 Fri Jun 01, 2018 5:29 am View latest post
