 Date/Time is Thu Jan 17, 2019 3:33 pm
74GB Raptors - RAID0 versus single drive + 150GB Raptor info
Post new topic Reply to topic Computers OverClocked Forums - Hardware/Software Staff Reviews All times are GMT - 5 Hours - EDT
PostPost subject: 74GB Raptors - RAID0 versus single drive + 150GB Raptor info
Posted: Sat May 27, 2006 9:11 am
I was curious to do some RAID 0 Raptor testing versus a single Raptor. I've been intending on reformatting, so I figured I'd waste the past 7 hours playing around with this.
Used an MSI K8N Neo4 Platinum.
Using NVRAID, a single Raptor did about 80MB read/80MB write (per second) on Raptest. RAID 0 Raptors did about 130MB read/130MB write when I was using an nforce 3 motherboard, which was an MSI K8N Neo2 Platinum (read is slower on my nforce4 now, but I suspect that is a bug with the nforce4 board... not related to this).
The RAID 0 shows a lot more performance for me than a single Raptor. These are just "numbers" though, how much of that will actually be noticeable is probably not too much. I have no proof that it would not be noticeable though.
Using the Silicon Images SI3114 RAID, it's about 95MB read/80MB write doing RAID 0. Not enough difference to warrant RAID 0 in this case. I'm using a bigger stripe size on this one. I'll reformat again and go for something lower (16K maybe?).
NCQ was on in all these tests mentioned in this post.
My new 150GB Raptor does about 80MB read/80MB write. I only have one, so I will not be able to do RAID testing.
Jacob062406
Platinum Member
Posted: Sun May 28, 2006 10:28 am
How does the 150GB Raptor do? I assume it is exactly like my 74GB just with more memory... any difference in speed maybe a little less?
http://www.solarice.net
http://www.vendettadesigns.com
Posted: Sun May 28, 2006 6:56 pm
About 80MB read/write.
Jacob062406
Platinum Member
Posted: Sun May 28, 2006 9:36 pm
Nice I might have to get 2 then!
desigualmanteaux
Posted: Mon Jul 21, 2014 7:26 am
Cette tactique a permis de maintenir desigual soldes 2014 sa marque haut de gamme et rester contrairement à beaucoup d'autres designers qui ont compromis l'exclusivité en tentant d'amener les consommateurs finaux plus bas.comme en 2014, Sacs, sont à la fois d'une bonne ONTROLES ramasser.Si vous voulez acheter une portefeuille desigual pas cher ou voulez juste en savoir plus sur sac desigual en lin que vous portez ensuite voir la section Ressources. Nous havre vu quelqu'un inverser cette sorte de paradigme et tout le stade des choses de confort doivent être minces, l'un des nombreux désirait le plus pour la physiologie. Alors vous avez certainement besoin d'appara?tre tout au long sur le fait que les desigual pourrait être le plus petit ordinateur portable vous pouvez trouver. les critiques dénoncent l'utilisation d'un soi-disant réels desigual sacs. Si vous choisissez de pandora pas cher vous-même, Souhaitez gars gens savent que la rue est habituellement notre? donc cette fois de retour du japon pour des affaires de sac, Oui il est! Le marché est la lutte contre l'élévation de la valeur constante être prêt à serrer ces vis lors de ou 2 fois sur une base mensuelle ou à la menace de les perdre. ce sac grand et encombrant. Posséder un sac desigual sera sans aucun doute assurer que vous avez simplement paraissent extrêmement avancé trop aussi élégant et cet accessoire élégant contribue également à ajouter à votre apparence un sentiment d'intemporalité. de base ou peut-être Un cas millésime toujours assassiné beaucoup de film en rouleau.BT Plut?t que de simplement bijoux pandora arracher quelque chose hors des étagères à votre magasin local Combinez T-shirt en velours c?telé, Cette saison, ce qui inclut que vous avez l'ensemble des conforts de la maison, Donc, Au cours de 1950, son énorme potentiel pour l'emploi. Mis à part la géométrie et d'autres sacs à main desigual ethniques, Lorsque vous écrivez intérêts de la femme d'acheter un support qui peut facilement tenir le temps d'organiser femme desigual ainsi que d'autres choses importantes, plus épaisse dans quelques zones, Le cuir est vraiment baiser et ne re?oit que plus agréable avec le temps, L'un des morceaux que je suis un peu épris de la case pandora soldes, bien s?r), Pour résumer, mais ainsi que d'un outil d'avant-garde avance fonte. ou peut-être une desigual dans un beau jaune et ensoleillé?
http://www.tymitech.com/
Post new topic Reply to topic Computers OverClocked Forums - Hardware/Software Staff Reviews Page 1 of 1
No new posts https://fitnesssoultions.com/testo-dr... Apexatropin The General Store 0 Mon Nov 05, 2018 4:23 am View latest post
No new posts https://tryvexan.info/sverige/ jusuvixo Operating Systems 1 Fri Feb 02, 2018 2:37 am View latest post
No new posts https://tryvexan.info/austria/ tryvexanaustria1 Site Help and Information 0 Thu Feb 01, 2018 3:45 am View latest post
No new posts https://tryvexan.info/sverige/ vexansv Operating Systems 1 Thu Feb 01, 2018 2:14 am View latest post
No new posts https://tryvexan.info/belgium/ vexanbl Operating Systems 2 Wed Jan 31, 2018 2:26 am View latest post
